Cornwallboater
- Dec 28, 2018
- 1
Good evening everyone, new here.
I have had many boats and always had outboards.
After a break from boats I've recently purchased a speed boat and bought a 1985 Suzuki dt140
Working my way through the list of issues and came across the tilt and trim not working.
Took the motor apart and the key between the motor and pump was off so put it back on and motor pumped oil lovely, reassembled it all and the tilt and trim will only tilt down and not up, can hear the motor working both ways just doesn't move...if I hold the trim up button I start to hear a bit of a screeching sound. Have tried lifting it manually, fling the reservoir and putting g it down on the motor a few times but still no joy. The tilt won't hold the engine up either it just let's it drop, any help would be much appreciated
Thanks
Thanks
