Motor starts fines and runs smooth. After couple miles cruising or 20 minutes putting around the motor develops a surging starting around 5000rpm. Onlty when warm. Carbs were rebuilt last september, fresh fuel with treatments.
It will go hard until 5000-5300 rpm then lose power, rpm drop to 4600+- rpm then get going about until hitting 5-5300k. maybe 1-2 second pulse.
Back off throttle to a cruising 3-4k rpm and runs fine, back off to idle runs fine and smooth. Get on plane nice, but surges start around the 5k mark. No surges happen when the motor is "cold" only once the motor has been running for say 20 minutes.
Any insite?
Any insite?
