andrew j cox
- Feb 11, 2015
- 149
So the F50 Yamster Ive been working on failed it’s comp test after head gasket, at least she’s not blowing comp into the water passages she’s holding 70 psi on 2,3 The others 1,4 are holding 125 psi, So I’m assuming she’s sucked the rings in when she was running hot, means now I have split the case, head off again , pistons out and hone the bores and try again, I’m assuming this is straight forward? Any traps?
