Bsellers22
- Aug 19, 2018
- 11
Looking for some help with my motor. Here is some background:
Warning buzzer did not sound prior to taking motor off the boat.
Once I took it off I decided to run it on the stand. Immediately after I turn the key over a straight buzzer is heard. This is the overheating buzzer but the engine is cold. I recently replaced the external oil tank pump but this can't be the issue because the onboard tank is full. I decided to disconnect everything to see if the buzzer goes off. With the temperature sensors and all oil sensors disconnected the buzzer still goes off when the key is turned. The only way the buzzer is not heard is when the pink wire on the buzzer in the 703 control box is disconnected.
I ran the motor for 5 min with the pink wire disconected confident the motor was getting oil and could not be overheating because it was cold. I was getting a steady stream and the cylinder heads were cool smoke was coming out at start up so it was getting oil.
So could the buzzer itself be bad? Look forward to yall's expertise.
