goinginsane
- Jul 21, 2017
- 1
I have an 87 DT115 giving me issues. It will start and run for 15 seconds they sputter and die.
Rebuilt all carbs.
Changed fuel lines from tank to motor.
Rebuilt fuel pump.
Emptied all fuel and refilled.
Checked compression and has 115psi on all cylinders.
Will restart every time but does the same thing - 15 seconds and dies. It doesn't matter if you increase throttle or leave it at idle it does the same thing each time.
My thought is a timing issue but as its all controlled by the CDI I'm not sure if there is even a way to adjust it.
Any thoughts or people who have seen this before?
I found a couple posts online with the same issue but no answer as to what the figured out.
Rebuilt all carbs.
Rebuilt fuel pump.
