BowPro
- Apr 25, 2012
- 73
Put the ears on the Vmax 150 today and the pee is strong from the tube, but there was no reading on the pressure gauge. I removed the cover to the pressure control valve and checked the spring and valve. That was all I did. I got the hot light a few years back and the pressure control valve was the culprit. In this case, it didn't overheat, just no gauge pressure. I put the lazer temperature gauge to each head after about ten minutes of garden hose idle. Each head was in the ballpark of 128 degrees. I'm just wondering... Is the hose forcing the pee or what? Would it possibly not pee in the water at the ramp? What can I check for at the house on the hose? Or whatnot. Thanks in advance.
