ANTI-
- Feb 2, 2018
- 7
While changing my water impeller I noticed the oil seal on the gear shifter was leaking. I decided to remove the gear shifter plate and change both the oil seal and the large "O" ring on the plate. Upon doing so I accidentally pulled up on the gear shifter, unseating it. Now I can't seem to get it to drop back down. Is there a trick to do this? Shouldn't it just drop in? I had the motor in neutral when I started this but it seems to be in forward now. Please help.
