Yamaha 15hp four stroke
countryboy996
Good evening,
It is an 2005 and I have had it about a year. It has always ran rough at idle. It was cutting off at idle until it was rebuilt the first time. It continued to idle rough but wouldn't die. Had a shop rebuild it again and now a new carb. Still idles rough but great other than that. I have changed all fuel lines, new tank, filters, non ethanol gas. It's only a pull start check compression both cylinders are about 70psi.
2nd question is.. at only about 3/4 throttle there is a winding sound almost like a super charger. Nothing above or below that rpm range. Any ideas?
