Hello! So, i am in the process of repairing an old DT100. Had to replace the cdi and bought a used one. It turns out there are two differences between mine (1990 model) and the newer unit i bought. Any input on this is much appreciated!
1. The number of pulsar coils has been reduced from 4 to 2. Not sure if i can just leave two of mine unconnected or not. If they are located at the same position, i guess so
2. A new coil is added to the stator/magneto. According to a service manual i found, it is called "power source" coil, and should output 11-12 volts when read with a peak (dva) meter.. i am thinking the CDI unit might be powered by this voltage and not from the battery itself, and i wish i knew the internals of the CDI then maybe this can be connected to another 12v source instead.
Anyone here have experience with anything like this?
