I have a 1986 Yamaha ETXJ outboard that after running and at idle, one head runs about 85 degrees and the other is at 110 degrees. Is that a thermostat issue? If so, who has them? Thanks
You can pull and replace then as Yamaha recommends or test to make sure they both work as the should. 85 sounds like it maybe stuck open if not both of them
