I got a 2002 Chaparral 265SSi with the 5.7GXI 320hp with Volvo duo prop, 230hrs on the boat. Got the boat last year took it out once engine sounded good but could only get the boat up to 4000rpm and roughly 38mph. So I chalked it up to bottom paint needing a redo(which still needs to be done) and propping. Boat was propped with F4s, I called a dealer they said my boat needed F6s. So I did the swap.
Fast forward to this summer, did the new props. Get out on the water, I picked up 200 rpms, but no real speed. And have also noticed intermittent starting issue, where I will have to give it throttle to get started and once I came off plane quick and it died. But boat does seem to idle alright.
I called the dealer I bought it through they told me boat had new risers gaskets, plugs wire and rotor and cap put on, also a new fuel pump. Verified the plugs were new, the cap and rotor looked new, wires weren't, they didn't look bad, but I replaced them anyways. Also this spring it had new oil, filter, fuel filter put in. Also replaced the thermostat and impeller. Boat operates around 150 degrees.
This GXI engine should run at least 4500 rpm at WOT, but Ive read where the GXI should go to 5000 or 5500RPM. can anybody verify this?
Anyways closest dealer is over and hour away, summer is in full swing, and the boat does work, so I don't want to go that route. I also don't want to keep throwing parts at . Just wondering if there are anymore ideas.
