MattJohnsonFLA
- Jan 10, 2014
- 13
Hey everyone,
Well after working through my last set of issues with the oil cooler I was able to get this motor to crank but not turn over. Noticed that there was a small but decent leak coming in from the transom where the clamping ring and the transom meet towards the bottom of the ring (appears to be here). Luckily a co-worker has a lot more experience with boats than I and prompted me to pull my starter to take a closer look for why she isn't starting easily. So when I pulled off the starter a solid 1/2 cup of saltwater (tasted it) came out, and the grease in the bell housing was definately mixed with water as well. Fixing the leak at the clamping ring shouldn't be an issue, a little 5200 after a good cleaning would take care of that BUT now with water in the bell housing I am not so sure I diagnosed it correctly.
After the several inputs I received at work for the culprit I was hoping for some direction here. For water to enter the bell housing, is the leak located where the sterndrive and gearing enters the bell housing from the aft?
Another theory was that the boat was filled with water either by a partial sinking or excessive rain water (doesn't explain the salt water)
You can see where that there was a decent amount of water in the starter based on the corrosion of the end cap (internally) and it wasn't cleaned or serviced for some time, either just trying to dump the boat or out of ignorance of the issue.
Well that's what I have so far, on the bright side the starter is still in good shape.
"So I got that going for me (goonga la goonga) - Carl Caddy Shack
