Welcome Guest - Sign Up today
No announcement yet.
riser gaskets with permatex ultra copper sealant
  • riser gaskets with permatex ultra copper sealant
    2005 4.3 GL-D. Just installed new riser gaskets and also used permatex ultra copper sealant. Anyone know how long a person should wait until trying it out? Does the permatex need to completely cure first?
    Re: riser gaskets with permatex ultra copper sealant
    Is the stuff you used one of the recommended types? Sounds like its brush or spray on.
    http://www.marinemechanic.com/volvo/...isergasket.pdf
    1998 Wellcraft Eclipse 24 Cuddy
    Volvo Penta Duo-Prop 7.4L "LK"
    2006 Sun Tracker Party Barge 21
    Mercury 90 4-Stroke FI
    "Common sense is not very common"
    "Failing to prepare is preparing to fail." -- John Wooden
    • #3
      yes, came in a squeeze tube with nozzle. Permatex ultra copper. It says on the pack 24 hours till full cure. I've put everything away for the night and will try it tomorrow aft.
      • #4
        You used a silicone based product?
        Don't think that will last.
        Might want to start over with new gaskets and the right sealant.
        Good Luck Muc
        • #5
          I used what was recommended by the Volvo service bulletin. Permatex ultra copper. good for up to 700 degrees F. I would imagine that all these type of sealers are silicone based.
          • #6
            NO
            Volvo recommends copper spray-a-gasket. It is more like a glue. Silicone is very slippery.
            The surface prep of the manifold and elbow is the important part --- looking to get the right amount of friction.
            At Volvo school they told us its better to install the gasket dry than use silicone.
            Please read the service bulletin Bruce posted and the instructions that come with the gaskets.
            Good Luck Muc
            • #7
              Click image for larger version
ID:	7085335 Has anybody else used this rtv stuff between riser gaskets?
              • #8
                [ATTACH=CONFIG]204063[/ATTACH] Has anybody else used this rtv stuff between riser gaskets?
                I used permeatex aviation sealant which seals in 10 minutes. i used it on riser gaskets and never had any problems. I also use it on automotive parts as well. On aviation parts that's all they use now. One bottle will last a lifetime
                • #9
ID:	7085370Thanks. I saw that stuff and read good reviews about it but kept hunting until I found the stuff listed in the service bulletin. Finally found some and some new riser gaskets.
