I have a 2000 Glastron SX 175 3.0 Volvo Penta. I was having problems with the starter motor. During its replacement the power trim started blowing fuses. As far as I can tell there is no power going to the power trim motor or the fuse before it. Is it possible that the wire between the starter motor and the fuse for the power trim could be shorted out? I have replaced both relays and was able to apply power directly to the power trim motor and it worked. Any ideas or suggestions?
