My 1986 Volvo has a 305 Chevrolet. The timing marks on the notched tab attached to the timing chain cover are visible and familiar. However there is also a label on the dampener with similar markings. It is a yellow sticker with BTDC and ATDC degrees, as well as a green stripe that appears to be TDC. Does anybody know if I line up the green mark to the appropriate numbers on the tab, or do I line up the 0 degree on the tab with the appropriate setting on the label? Ive never seen this sort of setup before.
