OK Guys I got a good one for you here.....<br /><br />I just bought the boat, (1986 Bayliner 19 foot)<br />I got a good deal on it, it has 700 hrs and an AQ131A engine in it.<br /><br />I checked the dipstick and it had a milkshake oil look to it......<br /><br />So before I start the boat or anything I drain the oil.......(that was fun), pull and change the oil filter....<br /><br />Then I hook water up to the outdrive and let it run (The water)......thinking if I had a cracked exhaust and it was getting in that it would do that.........er, wrong......needs to be running it appears but that's all good.<br /><br />So I check plugs, they're good, distributor caps/rotor/points (?) need changing but the previous owner did the plugs and wires.<br /><br />So I check the oil that I drained and it does NOT appear to be water in it, it APPEARS and smells to be gasoline......and how........<br /><br /><br />So I take the fuel pump off, check it's vacuum to see if the diaphram broke because what faster way to get gas in the crankcase.......(PcV?)......fuel pump is great.<br /><br />So I hook water back up and fire her up, been sitting so it took a while.<br /><br />She runs great.<br /><br /><br />So what's up with the tan oil?<br /><br />The new oil was only in there running for 5 mins, I shut her down because I think the fuel line was split and I didn't help it (5 min fix tomorrow in daylight).<br /><br /><br />Is there a PCV system on this that I missed?<br /><br /><br />I'm not seeing anything wrong with the boat...<br />I'm just concerned I will get more gas in the engine.<br /><br />BTW - The engine inside was SUPER clean, you could eat off of it......except for the gas and oil <br /><br />Could this have been a winterizer thing he did? Maybe some compound that smells like it?<br /><br />It idled good but I did not throttle it up in the driveway.<br /><br />Thanks,
