I have the above engine on a stand and need advice on how to run it on engine stand out of boat.
Here is what i know:
1. Connect water cooling
2. Connect +ve battery cable to Starter lug
3. Connect -ve battery cable to Engine ground
4. Connect a separate +ve wire to purple wire on back of alternator
5. Crank engine over by touching / jumping the yellow/red wire on starter
As this is an EFI engine with ECU what other connections do i have to make (i have attached wiring dia for this engine but am not confident this dia is correct as there have been other mistakes in the manual)
