I have a 79 IMP 5.7 GM 280T (Power trim). There is a noise comeing from the part between the motor & Out drive, sounds like between flywheel and transom mount/ steering swival. It sounds like a worn bearing. The noise is pretty consistant, though I haven't taken it out since hearing the noise. It does not get worse when the wheel is turned which leads me to think it is the gimble bearing (Or the VP equivalent). On my last post it was said that I have to pull motor in order to reach the bearing in question. Does the outdrive have to be taken off as well? Can anyone explain how to get at the bearing. I have the clymers but for this boat it is less than usefull.
