grandefermagio
- Jul 6, 2003
- 2
I have a twin engine Volvo Penta 5.0 GL. About a month ago the starboard engine overheated and hydrolocked. I was lucky I removed the plugs, blew out the water and changed out the impeller. Everything has been fine. So, being the concerned boat owner, I promplty changed out the impeller on the port engine. The impeller was not in to bad of shape just a few small peices missing. Well when I got on the lake this fouth of July the port engine started to overheat. My first thought was I had rubber impeller parts in the cooling system. I didn't find any anywhere. So I thought the thermostat was bad I removed the thermostat and checked the housing for blockage. Since I was on the lake I tried running without the thermostat. Still overheating. I flushed every hose that I could and didn't find and blockage. When I run the engine with a garden hose it seems to be fine water flows through the engine normally until it heats up to about 175 and then flow stops. If I allow the engine to cool it flows fine untill it heats up again. I'm stumped!
