1988 volvo penta 4.3 oilpressure
orion208
Hello: I have a Wilker 1988 with volvo 4.3 single prop.when reving at 4000 rpm oil pressure is at far mark on right "H" is this normal when I come down to 300 rpm it falls to just below the "H" line engine temp and everything else seems fine motor runs great at all other times is this a problem or should it be ok.Thanks
Lark40
Re: 1988 volvo penta 4.3 oilpressure
It's a lot less of a concern than low oil pressure.<br /><br />Are you using the recommended straight 30 weight oil?<br /><br />Maybe you have a problem with your guage or sensor.
