Welcome Guest - Sign Up today
No announcement yet.
Volvo 280 installation manual
  • Volvo 280 installation manual
    I am converting a hull from a Mercruiser MC1 drive to a Volvo 280 drive.
    I have the donor boat and ALL the pieces needed for the conversion. I just downloaded the template, is there a guide to go with this?
    Thanks
    Boat restoration is like eating an elephant, just take it one bite at a time.
    75 Tahiti 16' Ski Boat
    Ford 302 V8 / Volvo 280
    Reinell T-180 complete Restoration with Ford 302 & Volvo 270 drive
    https://forums.iboats.com/showthread.php?t=422361
    Re: Volvo 280 installation manual
    What are you unsure of regarding the template?
    '88 Baretta Success 200
    Volvo Penta AQ260/275
    '96 Weeres Suntanner 24
    '01 90hp Johnson
    • #3
      Hi Captmello, just want to confirm the procedure. And confirm that the 'S' measurement is the distance between the keel and lower transom shield bolts.
      And if the crankshaft centerline is the same between Volvo and Mercruiser drives so. If they are the same I can put both Volvo and Mercruiser templates on top of each other to aid in the transom hole cutting.
      I hope this makes sence
      • #4
        S or X dimension is the crankshaft centerline of the the engine. Here is a picture I put together that shows where the Volvo and Merc centerlines are exactly the same, and what the cutout would look like.
        The template will tell you the location by transom angle.
        Don S.
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          Thanks Don, that is very helpful. I should be able to scale you diagram to the mercruiser template for correct hole positions and cut out. That way I can put the templates on thin ply, temp bolt it to the transom using the existing mercuiser holes to trace the new volvo holes and cutout.
          • #6
            Don, would you have a full template for mercruiser on that shows the mounting holes?
            I have photoshopped your diagram with the 270-280 template that shows the mounting holes and sizes for the volvo cut out. It would be good if it showed the mercruiser holes too.
            Could be used for people converting:
            Mercruiser to Volvo
            OR
            Volvo to Mercruiser
            Here is a link to the full size conversion template I have created (it is 5.9mb, too big for forum)
            http://i567.photobucket.com/albums/s...r_template.jpg
            • #7
              I see what you mean, the template is a bit vague as to where the s measurement is. I agree that it appears to be the bottom two bolts of the transom shield but I can't tell for sure.
              '01 90hp Johnson
              • #8
                Here is a link to the SX full size template. It's the same as Merc.
                http://www.4shared.com/document/tCGr...out_templ.html
                Don S.
                • #9
                  i have completed my mercruiser to volvo template and have posted it on my server in PDF format.
                  If you think it is suitable feel free to add it to your batch of useful information.
                  http://sohotstudio.com/Boating/volvo...r_template.pdf
