There have been some reports of the outdrive bolts failing on various Volvo Penta outdrives.
Looks like #5 and #6 are the bolts used to hold it all together.
#5 ? Stud 3883255 QTY REQUIRED: 6 $3.69
#6 ? Stud 3883256 QTY REQUIRED: 2 $3.87
Can someone confirm that these are the bolts that have been failing? I do not see a nut on the end of these studs, do they thread into the transom shield?
There have been 2 boats that I know of that have sunk due to these failing, which allow the unit to be pulled away from the hull, letting water in.
