Welcome Guest - Sign Up today
No announcement yet.
volvo Penta model 100
  • volvo Penta model 100
    Hey there i just picked up a 1970 Pere Marquette, with a 130hp volvo penta..... My question is the out drive shifts with the cable, but the outdrive spins in forward consistantly. I am new with boats and especially i/o any help would be great.
    brett
    Re: volvo Penta model 100
    the prop spins fw in rev also? is it really doing that or does it just appear to be?
    • #3
      I am positive it spins the same way no matter what gear is selected.... So i was thinkin, is it possible it is just from sitting?? the boat has been sitting for years(5 maybe more). If so would it be dumb of me to fill it with good oil and put the muffs on it and let it run in the garage for awhile?
      • #4
        Changing the drive fluid could also give you an idea of what condition the drive is in.
        It sounds like you've had it running already. If your going to run it, make sure its on muffs and change the impeller in the raw water pump. Watch the temp.
        Are you sure its a 100? I've never seen one.
        Post a pic if you can. engine too.
        There's a few guys running around with aq130s on this forum.
        '88 Baretta Success 200
        Volvo Penta AQ260/275
        '96 Weeres Suntanner 24
        '01 90hp Johnson
        • #5
          ok guys i could be wrong. the motor is a aq130, but the shop manual says in handwriting that the outdrive is a model 100... so i assumed they did the research but maybe not. Anyways i ran it today with water for quite some time and i think i figured it out, time for a rebuild. It looks to me like the shaft poked through the top cap(see pics).
          • #6
            Here is a link to the OEM manual for the drive and the engine.
            Might help. I personally know nothing about the 100. Did you try shifting the drive "At the drive" with the cable disconnected?
            Drive = http://www.4shared.com/file/13026364...100_Drive.html
            Engine = http://www.4shared.com/file/59747156..._Serv_Man.html
            Don S.
            Please, no PM's (Private Messages) regarding boat/engine problems.
            That is what the forums are for.
            Only forum/moderator issues will be answered in PM's.
            • #7
              ouch! didnt see that one comin
              • #8
                You need to rebuild the upper gear. Contact Volvo for parts. They will give you the name of someone that has obsolete parts.
                • #9
                  I would bet there are few if any 100 parts around.
                  Don S.
