Mariah1993
- Sep 9, 2020
- 1
Hi all,
I bought a used boat recently that has been nothing but trouble. It’s a 1993 Mariah 2200zc with a Volvo Penta 570 engine. It’s been running poorly since I’ve owned it so I finally did a compression test. Cylinders 1, 2, 4, 6, and 8 were all around 200 psi but cylinders 3, 5, and 7 were WAY too low; between 10 and 30 psi each. These 3 cylinders are side by side by side so I’m thinking that it’s either a blown head gasket or *gulp* a cracked engine block. Supposedly the block was replaced a year or two ago. I don’t know if that bodes well or if that is a red flag seeing that they may have been in a used engine block. Any other problems you think it could be that would cause near zero compression in 3 cylinders? Open to any suggestions!
Many thanks
Many thanks
