Details: 1996 Volvo Penta (Ford) 5.0 FI (model 50FAPNCS) with OMC Cobra SX outdrive
Problem. Long cranks before starting mostly when warm, can take 5-8 seconds before starting. If it's being started within 20 minutes of running, it starts immediately. After sitting for 30-90 minutes, long crank (5-8 seconds), and sitting longer like overnight seems to be a bit better but still cranks 2-3 seconds. Idles and runs at speed with no problems.
Troubleshooting:
-Connected fuel pressure gauge with engine cold. Priming fuel pump once showed 7 PSI. Cycled key off and on, and pressure increased to about 20 PSI. Did this several more times and pressure maxed at about 39PSI. Lost 4 PSI in 10 minutes, 9 PSI in 20 minutes.
-Pulled fuel injectors out of manifold still connected to fuel rail and primed fuel pump (this shot one of the injectors out of the fuel rail, used zip ties to hold them all in). Got system up to pressure by cycling key and observed no leaks from injectors.
-Disconnected fuel pressure regulator from return line and put fitting into a bottle to catch fuel. Primed fuel pump and observed strong flow of fuel from regulator return despite fuel pressure starting very low and having to prime pump 4-5 times to get up to pressure. Stream of fuel came out of regulator return each time pump primed. But after priming I didn't see any fuel dripping or leaking from regulator return. Pressure continued to drop.
My questions are
1) is it normal for the fuel pressure regulator to allow a significant amount of fuel through the return when fuel pressure is low
2) If it's not the regulator or injectors, the only other option I can find is the high pressure fuel pump check valve. Any way to test this?
Troubleshooting:
My questions are
