Welcome Guest - Sign Up today
  • Dear Community Members,
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change. What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 9/30/2020! The whole transition should take 24-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
5.0 GXI-E Overheating
  • 5.0 GXI-E Overheating
    I have learned quite a bit by reading previous posts on this forum, but I could use a hand. My dad has a 2004 FourWinns that has a Volvo Penta 5.0GXI-E. For about 3 years we have been experiencing intermittent overheating issues. He has had the local marina out several times and they pretty much swap the impeller and leave. This weekend I went ahead and swapped the whole raw water pump and impeller. The prior weekend I couldn’t drive the boat under 3K RPMs without it overheating. After swapping the pump this weekend, the boat works perfectly while operating at anything over 1K RPMs. If I drop under 1K RPMs, the heat will slowly start climbing. Any ideas on what else I can troubleshoot? It’s just really frustrating because if we get in a no wake zone, we know the temp will start to climb. The boat is solely used in freshwater.
    Have a look at this it might just be your problem. https://forums.iboats.com/forum/engi...ne-at-2000-rpm
    Cranchi Ellipse 21
    5.0Gi (PWTR) 1999.
    DP-SM outdrive
    • #3
      I went ahead and replaced the thermostat today, so that’s not an issue. I drove around the lake just fine today at normal operating speeds, but it can’t go below 1K RPM without overheating. I shot some temperature readings while it was hot and it seemed like the area around the circulating pump was the hottest. Is that area supposed to be hot? The impeller was right around 100 degrees as was the manifold area. The area around the thermostat was about 185. The area around the circulating pump was about 197.
      • #4
        I fitted 2 x clear plastic hoses from thermostat housing to manifolds, and observed that at 600 rpm I had little or no flow to the manifolds. Then at 1500 rpm I had a stuttering flow. At 3000 rpm I had a continuous flow however there was gas entrained in the flow.
        This was the cause, exhaust gas had eroded the bronze tube, that is on the raw water suction side.
        Cranchi Ellipse 21
        5.0Gi (PWTR) 1999.
        DP-SM outdrive
        • #5
          look at the raw water inlet casting on the drive. if its plastic, it may be cracked. if its metal, it may be corroded.
          Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
          1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
          Past Boats
          1970 Wooster Hellion - Merc 9.8
          2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
          1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
          What’s behind you doesn’t matter.Enzo Ferrari
          • #6
            Check the power steering cooler hasn’t got an issue.
            apart from that, is the alarm sounding ?
