Hello,
I have a 2006 Volvo penta 4.3GL. After replacing my throttle cable and sterndive bellows, I reconnected my battery and tried to start the boat and would only crank, not turn over. So I primed the lines and it started right up. Turned it off and then same issue, had to reprime the lines to start it. Boat runs all day long with no issues until I shut it off and try to restart it. Replaced the line going from the fuel pump to the carb since it was old. Don't see fuel coming out of any other lines. What should I be looking for here? Any advice helps!
Thank you!
Thank you!
