Regal1973
- Feb 15, 2018
- 106
First I'd like to apologize but this is going to be like a reading a book LOL ! But please read through it thank you.
I posted back in 2018 about
a cabin cruiser my family and I purchased with a 5.7 L Volvo Penta GI G motor. It was a new to us 2008 year boat purchase and after sea trial is when I started having idle and running issues. Many of you guys assisted me in trouble shooting and it was discovered that it was taking in water into motor!
Fast forward, I ordered a brand new Factory Volvo Penta motor from a reputable company in Michigan. I had it shipped to the Tampa Bay area where I had the motor installed by a Volvo Penta certified shop. Since the day I picked it up I've had nothing but issues
It has had a idling issue since the day we took it home. It idles up and down about 100-200 rpms. It appears to be temperature related and when the temperature drops below 160, it runs perfectly smooth. When the temperature is above 160, it starts idling up and down approximately 100 to 200 RPM.
the Volvo Penta shop who installed the motor assisted in trying to address the issue and after jerking around, off and on for about a year, they were unable to figure it out. They hooked up a laptop and according to them, everything seemed to be within spec. Thinking it could be a problem prior to them performing computer diagnostics, they installed a new crank trigger which did not fix the issue. They have washed their hands of the idle issue and said there is nothing else that they can do for me!!!!! GRRRRRRR! which left me mad as h*ll!
Over the last 6-8 months Ive been working with the marine motor company in Michigan who I purchase the new long block (not rebuilt) VP motor from. They have been very helpful in trying to diagnose over the phone this issue. I even rented a diagnostic tool from them and went over the different operating parameters of the motor and it appeared as though everything was okay. Their last suggestion was to see if the motor is sucking air so they suggested I install clear hose on the suction side of the raw water pump. Just to eliminate any concerns, I installed a brand new raw water pump as well. After connecting the clear hose to the suction side of the raw water pump, I was sucking a ton of air into the motor on the garden hose. Hoping this was the issue to my idle problem, I traced the hoses all the way back to the transom. Outside of the transom I removed the hose off the outdrive and connected it to my garden hose. Running water with the garden hose connected to the hose which is connected to the outside of the transom, I had no air going through the motor, THUMBS UP, so I'm guessing the air issue is somewhere along the outdrive......
even with eliminating the air in the motor, unfortunately my idle issue was still there THUMBS DOWN.
I then connected the garden hose to the muffs on the outdrive and attempted to force water up through the drive and out the back of the drive which was a no-go! I could not get water on the garden hose to flow up and out the drive. I reversed the hoses and connected my garden hose to the back side of the drive and water flowed out freely down through and out the lowerr water pickups where the muffs attach. I'm confused on why I can't force water up through the lower pickups & out the outdrive hose which normally connects to the transom.
when I reverse the water flow, forcing it through the transom hose, it flows freely down through the lower pickups. Is this normal? When everything is connected back as it should, water is flowing to raw water pump and I know it is because I still have the clear hose connected to raw water inlet side & warm water is exiting the drive.
as for the idle issue, I have no clue what is going on.
I installed a brand new 250 degree thermostat. When the temperature is above 160, it idles rough. As soon as it drops below 160 it idles perfectly smooth. This happens like clockwork. If anyone has any ideas, for the idle issue or the outdrive flow as I explained, please throw them at me. This idle issue has been ongoing for a year-and-a-half now and the shop has wash their hands clean of it because they cannot figure it out either.
Thank you for any help!
