I have discovered that the heat exchanger lower end cap seal has failed. Unfortunately I have no idea as to how this has happened, I havent touched it so probably the shop has overtighten it or something...maybe years ago already.
anyway, this is how it looks, so clearly it needs to be replaced. But the question is - if I loosen the lower end cap, is it raw water or coolant that will flow out of the heat exchanger body?
