rperla
- May 21, 2005
- 62
Had carburetor rebuilt. After pumping the gas about three times then turning the key to start, will start a minute then stall. After the same procedure 3-4 times will start, but if I try to accelerate will stall, If I use the quick start, it will usually keep running. When in idle if I accelerate, it sounds as if the carb is sucking in air, it makes a vacuum type of sound. If I can accelerate to a higher rpm and get past the vacuum sound it will run at a higher rpm. It appears as if a low mid acceleration gets this vacuum type of sound. I thought of changing carbs, is there any other solutions? Thanks
