Good Evening. I'm have a problem with my 2000 yr Volvo Penta 5.7gs. It shut stalls out after a while .Acts like it's running out of fuel. went through the entire fuel system all good. fuel pressure stays up as it's dying out.Carb still has gas in it.started checking out the ignition system found Distributor is to hot to touch. Coil is not. Distributor has the BID Module in it no longer serviced by Volvo. Has anyone run into this and how did you fix it
