I pulled my lower unit as I do every year for winterization. This year I found my drive oil slightly white in color. It appears I may have a very slow leak somewhere. I have pressure tested the unit and it held 15 lbs for 24 hours. Vacuum tests show a slow loss over an hour or so. Which seals would be bad based on this information. Pressure good, vacuum bad.
The prop seals are original, 10 tears old. All other seals have been replaced over the last couple years.
