bhollehday
- Aug 16, 2017
- 77
My low pressure pump is noisy and it’s had a couple hard starts every once in awhile. I’m having it serviced at a shop and he is saying to replace the whole fuel pump kit assembly. He said my pressure and vacuum checks out on both high/low pumps, but to be aware it could give out anytime. The pump assembly is upwards of $800. I found some low pressure pumps online but the shop says the way the assembly works, you can not replace just the low pressure pump. You can the high pressure but not the low...
any one have some invite on this? Is the low pressure pump replaceable?
I found this along with some others
MOSTPLUS Low Pressure Fuel Pump for VOLVO PENTA 4.3/5.0/5.7 GXI injection 21608511 https://www.amazon.com/dp/B07GJF9XK4/ref=cm_sw_r_cp_api_i_b2LNDbS7GRXTT
