familymanbob
- May 30, 2010
- 26
2012 Regal 24 FasDeck 24’
Engine- Volvo Penta 5.0L GXIC-P (40869138)
Outdrive- Volvo Penta DPS-B 1:95 (21615543)
Team - thanks in advance. I can’t seem to find this issue on the forums, but happy to read a link if anyone knows of one.
I purchased this boat used last year and ran all season with no problem. In the spring, I replaced the gimbal bearing, bellows, and aligned the engine when reinstalling the lower unit. We had a hard time getting the lower unit off because alignment was out significantly in my opinion.
For the first several trips of this season, everything was perfect, no issues.
I have no check engine lights on, and the regal engine diagnostic (onboard system) shows no errors. When the boat is in the water and engine is NOT in gear, I can easily exceed 1250 -1350 RPM’s. However, under a load, the boat will not exceed 1250-1350 RPM’s.
I can kill the power to the entire system (via battery off switch) and then restart the boat and it will start, run and plane just fine. But after about 5 seconds of plane, it will drop back down to 1250 RPM’s.
I’ve considered the throttle arm, but it’s a little more money than I want to spend with ‘hit and miss troubleshooting’. Not sure how to test it. But then it doesn’t make sense because I can exceed the low RPM’s when not in gear in gear (with hose connected out of water). Engine seems to accelerate when low resistance on prop. Lastly, if I turn the wheel sharp right, the boat will exceed 12-1350 RPM.
Could this still be an alignment issue? As a side note, this is not my first boat, nor my first lower unit job, I’ve repowered boats, rebuilt wiring harnesses, etc. that said - I am teachable and willing to admit my own errors
I do not have an engine scanner, but again, it seems the built in code reader would tell me something if it were sensing a problem.
Appreciate the guidance.
