M_Dennis87
- Jul 29, 2019
- 4
So I've been battling with my yard sale special 2001 Cobalt 190 and have come to the conclusion that my motor is toast. Long story short the motor has a serious knocking going on, and after changing the oil multiple times I've found a lot of fine particles in the oil. I probed around with an automotive stethoscope and the noise is for sure coming from the bottom end. Below is a video of the noise after changing the oil twice and revving it up a bit.
I'm pretty sure at this point I have a blown rod bearing or something substantial broken in the bottom end of the motor. There's also a lot of corrosion in the valve train so at this point I'm looking at long blocks. I don't have the space or the time to pull the motor and tear it down, nor do I think it's the most cost effective solution. So the question is, where do I look for a long block? My local shop recommended Quicksilver but their prices were quite expensive. I was looking at Michigan Motorz at the different options, but I'm wondering if anybody has an experience with them. THIS is the motor I was looking at, which I believe is compatible.
To date, I've replaced all the old gas, fresh oil, spark plugs, raw water pump, u-joints and gimbal bearing. Any additional info / advice would be greatly appreciated.
https://youtu.be/KcBowRsw1eY
