ForestRanchSteve
- Sep 7, 2019
- 2
Neither the kill switch nor the ignition switch will stop the engine. I have to pull the coil wire to get it to stop. The engine overheated just before this started happening. I've looked for a diode as I have read that this is a problem with the 4.3 engines but cannot find one. I suspect this is due to a mechanical fuel pump.
The alternator seems to be working just fine. The voltage is over 14 when running with no load.
Any ideas?
Any ideas?
