Welcome Guest - Sign Up today
No announcement yet.
R+R wye pipes
  • R+R wye pipes
    My wye pipe are coroded and need replaced. Manifolds and risers are off . I need a brief step by step guide to help me minimize extra work. My ability is good but no marine exp. Working on 1990 chaparell 2750sx. Twin 5.7l's
    Welcome to the forum.
    Remove the fuel line, disconnect the wiring plug, remove the drive, remove the rear motor mounts, remove the side motor mounts and yank the motor. Repeat for the other motor. Y pipe replacement can only be done with the motor removed or slid forward.
    BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Yep....what he said....you gotta pull the motors
      Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
      1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
      Past Boats
      1970 Wooster Hellion - Merc 9.8
      2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
      1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
      What’s behind you doesn’t matter.Enzo Ferrari
      • #4
        Thanks for the info. The motors look pretty easy the drive is the new thing. But I'll work on it for awhile. Any body got an idea for where to get 2 long blocks?
        • #5
          Ayuh,..... Welcome Aboard,..... You can get brand new long block crate motors from yer local GM dealer for 'bout 2 grand a piece,.....
