Augoose
- Mar 21, 2010
- 1,220
Well,
For all the times I've towed others in, it was my turn today.
In an attempt to troubleshoot, here's what happened....
The boat ran normally today at first. We ran about 40 minutes, moored the boat in rough chop with the stern towards land and the bow into the wind. The chop was about 2' swells on average and the boat was bouncing around quite a bit for several hours.
Went to leave and the boat started normally. Idled away and ran for about 20 minutes at headway speed, just cruising. Went to increase throttle and the boat stumbled a bit.
This stumble has happened before - maybe once every 5-6 times out. The stumble in the past has always cleared up when I eased off the throttle and then got back on it again. Usually it was when I was getting on the throttle hard pulling a skier. It was the same symptoms today. I didn't think much of it other than making another mental note to figure out what's causing it.
So we continued, running the boat at about 2,500 rpms for about 20 minutes. Everything seemed normal and then the boat started stumbling again. At the same time, the radio started cutting out. The boat then seemed to enter what I can only describe as a limp mode. The boat would run and sounded like the engine ran normally, but only if you kept the rpms low, say around 1,500. As soon as I tried to increase throttle it would stumble again.
Oil pressure stayed normal, engine temp stayed normal, but the voltage was reading 11.7v according to my fish finder.
After another five minutes or so while running in the "limp mode", the engine stopped. When I attempted to start it, it sounded like the bendix gear would only spin and not engage the flywheel. I tried tapping the side of the solenoid and it didn't do any good.
So, I was initially thinking hydro lock. However, I think that is unlikely because ever since I started noticing symptoms, the engine never suddenly died and in general I never allow the stern to get swamped, such as cutting out the engine while on plane. Even when exhibiting symptoms, the engine would run well and it "sounded" strong until I asked for more throttle. Then it quit.
Now I'm thinking I have a bad or failing alternator or a bad connection somewhere. Considering my radio started having issues at the same time the boat when into "limp mode", I'm wondering if for the last several months my alternator hasn't been keeping up with charging the battery properly and when I'm at open throttle, there is more demand from the electrical system than it can deliver, such as the operation of the fuel pump? The engine then starts stumbling (weak spark), the radio begins to cut out, and then it dies completely? Then when I attempt to re-start the engine, only the bendix gear spins, possibly because the solenoid has failed too? Is that just a coincidence?
In an attempt to troubleshoot the electrical system, I've put the battery on a maintainer. The plan is to attempt to start the boat again on muffs to see if a charged battery changes the symptoms. I then plan on pulling the alternator and taking it to one of the auto parts stores for them to test since the electrical system was reading 11.7v.
Thanks for any suggestions or help
