Welcome Guest - Sign Up today
No announcement yet.
Volvo 4.3 Backfire During Acceleration- Need Help
  • Volvo 4.3 Backfire During Acceleration- Need Help
    I have a 2001 Four Winns Horizon 180 with a 4.3GL-PEFS (serial number 4012036774). The motor fires right up and idles well, however the idle jumps around within a range of about 20-50 rpm. I have ran 15-20 tanks of fuel through the boat over the past few months. The issue is when I go from idling to a hard acceleration the engine backfires and it sounds like it's backfiring through the carb. (only under load) If I accelerate very slow it won't backfire, also if I do a couple quick pumps of the throttle and then accelerate hard it won't backfire.
    Things I have done in the past week:
    -rebuild carb with Holley marine kit
    -new cap, rotor, plugs, wires, ignition coil and ignition module
    -reset timing (the timing does advance)
    -new fuel filter
    -new fuel line
    My thought is that I need to adjust the accelerator pump so that is squirting fuel earlier, not sure if this could cause my issues? Anything else I should try?
    Thank you! I am running out of ideas
    Need to get back into the carb and check adjustments like float setting, accelerator pump, main jet circuits.
    Also with a Holley it may have a stuck power valve, or if it was replaced then could be the wrong one was installed
    Its backfiring because of a lean condition. Was the timing set according to the service manual?
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 Seadoo GTX
    Merc Adults Only VP Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      pull the primary bowl and metering plate...... clean out every passage and chase it with a fine wire or monofilament line
      then install new gaskets, new power valve and new accelerator pump and check valve. then adjust your AFR
      your running lean on your accelerator circuit, and most likely on the idle circuit as well.
      Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
      1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
      Past Boats
      1970 Wooster Hellion - Merc 9.8
      2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
      1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
      What’s behind you doesn’t matter.Enzo Ferrari
      • #4
        Believe it or not the Holley 4160 for the OMC/Volvo V6 does not have a power valve....I have one sitting in my garage....
        https://www.holley.com/products/fuel.../parts/0-80492
        1988 Four Winns 200 Horizon
        4.3 OMC Cobra
        98 Jeep Grand Cherokee 4.0 Selectrac
        07 Jeep Grand Cherokee Limited 5.7 Quadradrive II
        "While air doesn't freeze....rust never sleeps"
        • #5
          the GL should have the 2300 2-barrel.
          Past Boats
          • #6
            I have the service manual and followed the timing procedure using the timing shunt and timing light. Also verified the timing is advancing. The float setting was within spec, the kit came with 2 power valves, one was a 4.5 and the other was a 2.5, the one that was in the carb originally was the 2.5 so I put that one in.
            I spoke with holley and they agreed it was running lean on the accelerator circuit and that I should verify that setting. If that doesn't work, I will try cleaning it out again.
            Its the 2300 2-barrel
            • #7
              I have a 97 4.3gl PLKD with basically the same set up. The rebuild kit came with the 2.5 and 4.5 power valve. I ended up going with the 4.5 and had no problems with the carb once I figured out what the real problem was. I ended up finding a bad lanyard switch that was the real culprit, but that’s a whole other story in its own.
