New to the forum and to boating.
I have a 1993 Wellcraft 202 Nova Spyder with a 4.3l V6 and 305 hours, volvol SP outdrive and a 15x17 aluminum prop. She had a 4bbl Rochester quadrajet carb.
Last weekend when I took her out with a fresh full tank of 92octane and two passengers no extra gear she started up right away and would idle fine. Ran out to the middle of the lake a d noticed the throttle was not responding beyond 2000rpm
Then at random she would stall out completely but would start back up on the first try.
If I put her out of gear I had no problem revving it to redline but once back in gear nothing beyond 2000rpm.
I assume my carb is clogged so I will do a rebuild. My question is should I be looking at anything else besides the carb?
