bstronger@hotmail.com
- Oct 18, 2010
- 3
You should know that the 1500 engine hour Volvo Penta timing belt replacement cannot be
trusted. My port side D3 200 failed at 1350 hours. The cause was a failed timing belt tensioner which allowed the cogged belt to slip. If you do not know the difference between a timing belt and chain or an interference and non interference engine
you may want to read up. The 5 cylinder DOHC D3 is a n interference engine with a timing belt not chain - a recipe for a very expensive failure. I suggest avoiding these engines and if you have one change the belt with the kit well before the recommended 1500 hours. FYI SOHC engine are generally not interference designs I.e. the piston will never hit the valves even when the timing belt fails - making for a simple inexpensive repair. I you need DOHC at least look for an engine with a timing CHAIN. Shame on Volvo.
