Hi, I have an issue with this engine. It won't start it self.
I tested the fuel pump connecting it straight to 12v and it worked but not energetically. I tested too the conection and it had power only while is cranking. I poured some gas in the carb, the engine started and run just fine. I disconnected the fuel pump while the engine was running and it stopped after a couple of minutes.
Thanks a lot for the comments...
