whitesharkseeker
- Nov 8, 2010
- 95
So I need to pressure test my VP 5.7Gi block for leaks. Suspect a blown head gasket do to water in oil but engine runs fine. From last post, salt water pouring out (and I mean pouring!) of RW reservoir. Engine now overheats. Pulled HX to pressure test but not much on web hot to do procedure. Read about bike tire but how do I plug up other outlets/inlets? My main question is: I may have two problems, bad HX and blown head gasket. How to I do a block test with heat exchanger removed? Pic of engine below. Thank you for help. Eric Mailander
