ChrisCraftFan
- Jun 18, 2013
- 184
Hi all! I am replacing the trim hoses and in the process I now have to replace the cylinders and manifold block. Unfortunately, the treads in them came out with the hose fittings. Anyway, my question is how tight the fittings should be? once i put that manifold back in i don't want to have to go back and fix a leak. They all have a rubber o-ring but i just don't know how tight to make them. The manual says "securely attach hydraulic lines" Too tight and I smash the o-ring too loose and it leaks. Anyone have some advice on that?
Also, how about some anti seize on the threads?? good or bad idea
