Welcome Guest - Sign Up today
No announcement yet.
Volvo Penta SX-C1 question
  • Volvo Penta SX-C1 question
    I've got a 1994 Marada with a SX-C1 lower unit. Water got into it and the upper bearing on the vertical shaft locked up. I took it apart and I am unsure on how to put it back together as far torque and shims. I got a Seloc manual but it does not tell me anything about the lower unit bearings and gears. Does anyone have a link to a manual or where I can purchase one that explains the process? The local boat repair shops does not want to work on it and the closest one that will is a 3 hour drive away. Any help would be greatly appreciated.
    the only thing the seloc book is good for is to chock the wheel of the trailer, even that may not be good. go to
    http://boatinfo.no/lib/library.html and look up the correct manual, it will give you all the specifics to do the job, its a lifesaver.
    good luck
