Lubak572
- Jan 4, 2018
- 235
Does the factory timing mark for TDC hit on both the exhaust and the compression stroke? I am firing motors and just lined up mark. I did not verify I assumed factory mark is on and hit tdc compression every time it lines up. My buddy says otherwise. So Does crank hit tdc compression on mark every other time mark lines up. Thanks.
