Welcome Guest - Sign Up today
  • Dear Community Members,
    Updated 9/29/20 - Upgrades have been pushed until 10/7/20
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change.
    What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 10/7/2020! The whole transition should take 30-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
Volvo penta aq131d power tilt not working
  • Volvo penta aq131d power tilt not working
    As I'm putting the boat back together I'm finding issues. Right now the power tilt isn't working. When I hit the switch I hear a click back there but no motor or movement. Fuses look fine. Wiring looks fine. No loose wires disconnected. Worked in the fall when we were putting it away. Any ideas on what to check?
    Thanks,
    Trevor.
    Battery is good, motor turns over without issue and I checked the fuse.
    Thanks,
    Trevor.
    • #3
      A good chance that one of the relays under the plastic cover is in need of replacement. Also if the cover is off be sure that the limit switch on the top of the tilt unit is connected and seated.
      Kenner, Louisiana 1980 Donzi 18'. 2+3 6.2 MPI Alpha 1
      • #4
        Is there a diagram or picture somewhere I can refer to? I did get the stern drive up by hot wiring the motor and the stern drive indicator light recognizes that it's up which is good i guess. Can't use it this way though.
        Thanks,
        Trevor.
        • #5
          Change over the relays and see if it does the opposite.
          • #6
            I took the cover off and it looks pretty complex in there. I can't easily identify a relay, looks like just a bunch of wires. I may have to take it to someone. This is beyond me.
            Thanks,
            Trevor.
            • #7
              Yes, it's a tight fit in there. Do you have the black contoured box?
              Dennis
              20' 1987 Renken Cuddy Cabin
              AQ131C 270 drive
              Southern NJ
              • #8
                I'll take a picture of it tomorrow on and off for referenc .
                Thanks,
                Trevor.
                • #9
                  Here's some pictures of the top electrical. As I said the motor is fine and I can hot wire it up and down but that's rather complicated to do when you need to.
                  Thanks,
                  Trevor.
                  • #10
                    Two relays and a limit switch in there. The relays are upside down, the wires slip onto the terminals. I would make sure all external connections are good first. Including the console switch for up-down. I need to find my old relay info, these are slightly smaller than the ones found in automobiles.
                    Go to this thread, my post #18 shows what I used in the past.
                    https://forums.iboats.com/forum/engi...lt-relay/page2
                    Dennis
                    AQ131C 270 drive
                    Southern NJ
                    • #11
                      So if I just get 2 new relays I should be good? I went back and can see how they pull out. The wires all look solid. I have no up or down so switching them won't help. I just hear a click with no further action or noise.
                      Thanks,
                      Trevor.
                      • #12
                        Here are some more pictures, I pulled what I believe are the relays out. They look hardwired and in good condition. Not sure if that matters or not.
                        Thanks,
                        Trevor.
                        • #13
                          Okay, now I see the real relays and stop limit. They don't seem to come out but I'll do some testing this afternoon as well
                          Thanks,
                          Trevor.
                          • #14
                            Ok . I wouldn't have found this on my own but with a friend that knows a little more than I do about relays stopped in and we were able to determine that both relays are good as well as the stop limit was also good.
                            Further testing revealed that we were only getting 8v at the relays. Battery was 12v, but started tracing back. Found that the 40a fuse was where it started. Sanded the ends on the fuse holder lightly and voila 12v all the way through and the power tilt now works as expected.
                            Thanks, hope this helps others.
                            Thanks,
                            Trevor.
                            • #15
                              You are the man!
                              Dennis
                              AQ131C 270 drive
                              Southern NJ
