Plowkingmaster
- Jul 2, 2019
- 6
I have a 1993 wellcraft excel 20ft boat with a (I believe) a 1991 Volvo penta 430a 6cyl engine . It has a disgusting knock in the engine with a bit of a squeak to it and looks like the crank is moving with the knock , also found a bit of water in the oil,
I'm pulling this engine out , the question is is there more than motor mounts on the engine holding it in , I looked every where around the bell housing and cant seem to find anything else holding it in , I did pull out the out drive and shaft and such .
