I had a Volvo penta 5.0gi which I got a new long block 2 years ago. Went with a Holley carb and swapped all my Volvo parts over. So for all intents and purposes I have a 5.7 gl now. Winterizing last year I had milky engine oil. I thought I narrowed it down to the manifolds and risers. I put new ones on this spring and went with the tall risers as I removed the flappers. I followed the directions to a t and harrassed many people looking for advice since I know the Volvo risers can be a bit finicky. I had the surfaces shiny, tapped the holes as recommended, torqued, retorqued all in a crossing pattern. I have no signs of water leakage on the outside and the risers are cool enough to touch and leave my hand on them.
I went for a cruise on Friday afternoon and it ran fine. On Sunday morning I went to start it and all i got was a clunk. I pulled the number one plug and water dumped out. I pulled the rest and there was water in all cylinders. The worst being one and 8. I turned it over by hand to get all the water out. Squirted some oil down the plug holes. Turned it over by hand again until nothing came out. Put the plugs back in and fired it up. I let it run for less than a minute and shut it down. Took the plugs back out and no water. Started it again and let it get to temperature. Shut it down and pulled the plugs... dry again. Went for a cruise and checked the plugs again... still dry.
The engine is fresh water cooled (half system) which I believe Volvo only makes the half kit. That being said, where is the water coming from? I tasted it and it was definitely salt water. With the half kit cooling system the only place salt water goes through the engine would be through the manifolds, risers, and out the exhaust, correct? Therefore salt water can only get into the cylinders through the manifold/risers or in through the exhaust. I thought maybe I backed up too hard on Friday, but I would think it would hydro lock immediately, but the next day. So I'm leaning toward the manifold/risers. But I had water in both sides... I know I could have not installed either side correctly but its 4 bolts to the riser.... and I followed the directions very carefully... it cant be that hard can it? Also, why would it leak intermittently? Any other things I should be looking for?
I should also mention that when I'm idling around temp.is around 170. When I give it some juice to get up on plane it will creep up to just under 180 and then drop back down to 170. I've never noticed it doing this before.
Also, the oil was clean... no water in the oil.
Thanks for any ideas on what to.do next. I appreciate all the help I can get..
