Howdy everyone! I hope the summer is treating you all well so far.
After finding water in the cylinders and pulling heads to find quite a bit of corrosion in a motor with close to 1,000 hours we have decided to go ahead and replace the motor with a rebuilt stroker and new heads while i've got her taken apart.
Boo!
Does anyone know of any resources to look at or opinions to share to help decide if adding a closed cooling system would be worth the effort and cost when the new motor goes in? While this is primarily a fresh-water boat it would be nice to have the option to run in saltwater with a little less worry about corrosion.
My thought process is that a closed system gets me a few benefits:
Are there any other pitfalls the more experienced members out there could bring to my attention before i get started down this rabbit hole?
As always, i greatly appreciate everyone who is willing to share their knowledge here.
Cheers!
Boo!
- Less corrosion in the block and heads even running in fresh-water.
- Easier winterizing.
- Ability to use in saltwater with less detrimental effects.
- Ability to run at operating temps closer to what the 350 was designed for.
Cheers!
